Speed fluctuations on gateways
Fixes: 4
I have speed fluctuations on some gateways and not others, can anybody explain this ?
I've dropped 2 hourly graphs below, one of the last 30 days and another of the previous 6 Months, On the 30 day graph you can see the gateway I was on for the last 20 or so days which seems to fluctuate at all times of the day, but if you look at the 6 month graph you will see multiple gateway changes, some of which are showing notable speed fluctuations while others are less erratic.
Fixes: 4
Re: Speed fluctuations on gateways
Andrue
Yup. I've just bounced my connection and now I'm on pcl-ag07 I'm getting better speeds. I reckon pcl-bng04 must have some kind of issue.
Definitely something going on that is not SVLAN related in my opinion, plusnet been silent on it tho, only checking svlan's or blaming lines.
Andrue
Yeah, mine has dropped back - single threaded mode anyway. It seems that multi-threaded download doesn't suffer and I wonder if that's related to the PN QoS? I'm speculating here but I wonder if it's treating each thread as an 'application' and is imposing a per-application throttle due to congestion?
It is not just for fibre, if not on a BNG gateway I get 4.7mbit, if on a BNG gateway I get 5.2ishmbit.  The down side is, I tend to get streaming issues with TwitchTV on the BNG's.
21CN on ptw-bng01 @ 5.3mbit
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Justin7
I have been noticing differences in ping and throughput consistency depending on the gateway I am connected to.
Sometimes a margin of an additional 5 ms in ping found by just changing gateway.
Also I sometimes get peak time buffering when streaming via I player or netflix depending on which gateway I am on.
Is there perhaps a load balancing issue with these systems?
rongtw
Fixes: 12
something is not right  Shocked i can play on bf4 servers daytime with no problems , then after 5 ish it gets bad .
same for streaming i player or any other TV station
Justin7
Is there any pattern to which gateways are performing better / worse?
Andrue
Yes. The ones that are performing worst belong to Plusnet  Grin
dick:quote
Fixes: 4
And now back to the bng gateway again shows the return of speed fluctuations of around 3mb, I'm not seeing any streaming issue at present on any gateway Gus, then again my exchange has recently had some upgrades on 13/01/15
rongtw
Fixes: 12
Dunno why BNG are bad for BF4  Undecided
Justin7
Well I'm not really sure of why there are these apparent differences but it was checked by Plusnet last week and no known issues identified.
Plusnet Staff
Plusnet Staff
I was just going to re-iterate that end to end checks have been done and that no issue has been found. Of course we'll look at individual cases via the usual methods.
 Tony
 Plusnet Support
Justin7
Throughput and latency has been good the past few days via the bng gateway.  Smiley
