Speed fault - 80Mb to 30Mb
FIXED- Subscribe to RSS Feed
- Re: Speed fault - 80Mb to 30Mb
03-08-2017 9:12 PM - edited 04-08-2017 10:32 AM
Hello
Currently our internet speed appears to be capped at 30Mb/s. Usually there is no issue attaining 75Mb/s+ on BTW speedtest.
The connection time is at 14days 13hours so there seems to be no issue in that regard.
As far as I am aware the only drops we get are the occasional momentary power outages we have had in the early hours once every 2-3weeks for the last few months (whole road, not just our property). We are always aware of when these drops occur as we have to reset various clocks when they do.
Please see attached screenshots.
Many thanks.
Moderator's note by Mike (Mav): Personal information removed from attachment in a public forum.
Fixed! Go to the fix.
04-08-2017 4:55 PM
04-08-2017 11:14 PM
Hi Gandalf, thank you for your response.
I connected to the test socket and ran BTW Speedtest (and an Ookla speedtest) - both came out at approx. 75Mb/s down, 15Mb/s up.
I have now reconnected the faceplate (BTOR MK2) and connected as usual. BTW Speedtest (& Ookla) now both coming out around 75Mb/s down, 15Mb/s up.
What is likely to have cause the low sync speed I experienced? Or is that impossible to really say?
I did begin a fault ticket, but marked as 'my problem is fixed' halfway through.
05-08-2017 12:13 AM
