Speed dropping slightly
KaotiK
Hey, so my speed and line has been stable and great, been consistant at 27.7mb down, 5.8 up.
How ever i noticed its dropped down to 25.5m down, when i check my router stats my line speed has gone from 31mb to 28mb.. I restarted my router last night to see if it helped but no luck.
Any ideas? I started off at like 29mb after the last engineer, then it dropped to 27mb down which i was fine with but cant really accept 25mb when its capable of more..
cheers
KaotiK
Re: Speed dropping slightly
VDSL Link Downstream Upstream
Link Rate 28972 Kbps 6000 Kbps
Line Attenuation D0( 22.7) D1( 66.2) D2(N/A) dB U0( 8.9) U1( 52.Cool U2(N/A) U3(N/A) U4(N/A) dB
Noise Margin D0( 6.1) D1( 6.0) D2(N/A) dB U0( 14.Cool U1( 15.1) U2(N/A) U3(N/A) U4(N/A) dB
VDSL2 Profile Profile 17a
My link rate there has been 31MB or so which has been sound, but its dropped slightly... any way to get that back up to where it was please? Sad
KaotiK
think i just need a line speed/ip profile reset? whatever it is?
Fixes: 238
We can't reset profiles remotely on fibre I'm afraid and in this case it wouldn't make a difference as your profile is "0.128M-80M Downstream, Retransmission High - 0.128M-6M Upstream, Error Protection Off".
I'd recommend raising a fault here to see if there's anything that can be done.
 Matthew Wheeler
