Speed dropped way below Minimum Guaranteed Speed
FIXED- Subscribe to RSS Feed
- Speed dropped way below Minimum Guaranteed Speed
18-04-2020 10:58 AM
Sometime over the end of March ~ early April my 'Unlimited Fibre Extra' download speed has dropped to about 25Mbps.
This is considerably below the stated Minimum Guaranteed Speed of 59Mbps.
That said the last time I checked at the end of Feb it was only ~40Mbs then, but as their are now 3 adults working from home (including a key worker) it would be good to get the service as contracted.
Can this please be investigated?
Thanks & Regards,
Graham
Fixed! Go to the fix.
Re: Speed dropped way below Minimum Guaranteed Speed
18-04-2020 11:41 AM
Same issue for me for past several weeks.
Likely due to all the extra (fibre) broadband traffic, but my speed has dropped through the floor.
”Contractual” parameters are:
- Product: Unlimited Fibre
- Estimated Download Range: 26 - 38Mbps
- Estimated Upload Range: 5 - 7Mbps
- Minimum Guaranteed Speed: 22.7Mbps
- Current Line Speed (Download): 29Mbps
What I’m actually getting is anywhere between 16 and 19 Mbps at any time of day. - <30% below guaranteed minimum.
Typically my speed over the past year or so has been no more than 25. That figure is very much diminished from when I first signed up for fibre when speeds were 33-36 Mbps!
Looks like the BT system has very low resilience.
18-04-2020 5:30 PM
We should get 18mb
Dropped to 13mb last year due to the old line.
Min Ofcom speed is 11mb
Now getting 8mb
Plusnet have ignored the fault report for a week.
18-04-2020 6:50 PM
How did you do the speed test?
Was it by accessing the modem statistics and getting the connection speed?
Was it by using a speed test such as ookla?, if so under what conditions was it carried out?,
wifi?
sole user?
19-04-2020 9:28 AM
Responding to dws 1900. Thanks for interest.
I am a Mac and iPad user with no possibility of a wired network connection so always use Wi-Fi. I’ve checked in the past using a borrowed laptop and with either the network cable or Wi-Fi results are identical. I use either BT Wholesale checker or Ofcom checker.
I‘ve not looked at modem stats - not something I know about.
Given the lockdown we are 2 in the house And no tests done when streaming etc.
Our “cabinet” is about 500m distant.
19-04-2020 9:44 AM - edited 19-04-2020 9:45 AM
Hi
assuming you are using the PlusnetHub?, login to the device (password unless changed on the back).
Then go to the trouble shooting panel (I am doing this from memory as I do not use the plusnet modem)
Then look at the helpdesk panel.
The parameters of interest are, for example
DSL uptime: 0 days, 00:22:17
Data rate: 2056 / 22138
Maximum data rate: 2056 / 22336
Noise margin: 5.9 / 3.5
Line attenuation: 37.8 / 31.9
Signal attenuation: 37.6 / 26.2
Post nothing else, use cut and paste
To access the plusnet hub if you have never done this before, type in
19-04-2020 10:07 AM
Totally ignoring fault reports says it all.
19-04-2020 10:13 AM
Hi
Thats why I have requested the stats, as he is only 500m from the cabinet, but of course that does not accurately reflect the line length.
19-04-2020 11:43 AM
Test setup:
Single user device (laptop) connected to 'Plusnet hub one' via Cat5e cable. WiFi shut down on hub.
Initial indicator is the sync/line speed as indicated on the hub: 33.48Mbps downstream & 19.14Mbps upstream.
Looking at the BTWholesale diag test, it gives a 30.98Mbps download result.
This correlates to a test using testmy.net (my normal test source) which gives a download result of 31.79Mbps for today.
When referencing the availability data via the BT Broadband availability checker, it gives the VDSL impacted range (I'm happy to be realistic and work from these figures) as 80Mbps (high) and 61.4Mbps (low), with the downstream hand back threshold as being 55.3Mbps (impacted).
Looking back at my saved results on 'testmy.net' it shows that at the start of my contract for Plusnet "Unlimited Fibre Extra" I was getting 75.5Mbps download in Sept 2019, so what has happened?
19-04-2020 11:48 AM
Some additional hub data:
3. Firmware version: | Software version 4.7.5.1.83.8.263 Last updated 03/09/19 |
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 3 days, 14:30:09 |
6. Data rate: | 19139 / 33478 |
7. Maximum data rate: | 28553 / 81479 |
8. Noise margin: | 11.1 / 20.3 |
9. Line attenuation: | 11.2 / 11.7 |
10. Signal attenuation: | 11.2 / 11.7 |
19-04-2020 12:05 PM
Hi
I would suggest you carry the procedure defined by plusnet where you plug the supplied filter into the socket behind the faceplate to rule out internal wiring, power down / power up the router and get the stats again from the router (if you are already connected this way, then just do the power cycle)
If there is no significant improvement, then request a GEA test from plusnet and also create a ticket, which will then get them to identify the issue.
Faults chasing requires elimination and patience, difficult I know, but it best to try and rule out the things you have control of first, even more so at the moment.
19-04-2020 12:27 PM
Hi again.
i discarded Plusnet modem long time ago and use Netgear Nighthawk and BT Whole home wireless discs. Plus Sky have added a wireless router for their tv box as BT/Sky not a good mix.
Interrogating Netfear data gives attached - good, bad or indifferent I don’t know.
Lets hope someone from Plusnet is eavesdropping on this customer dissatisfaction
19-04-2020 12:34 PM
Unfortunately I cannot get the information from your jpeg (magnifying it takes it out of focus), can you try again at a higher definition, or transcribe the information into a text file?
19-04-2020 12:54 PM
Herewego with a bigger, better pic
19-04-2020 1:49 PM
This appears to be the quantity of traffic you have passed. What is required is the connection speed, usually expressed in Mb/s.
The connection speed (or sync speed) is the speed between the modem and the cabinet, which should be higher than the Minimum Guaranteed Speed.
The connection speed is not the speed that a speed test shows, speed test results would be lower than the connection speed, and will be influenced by using wifi for the test, and/or additional traffic during the test.
For example performing the test while downloading a film will reduce the speed test result, but not the connection speed.
If you can find the connection speed, there will be two, upload and download, and the download speed should be higher than the Minimum Guaranteed Speed. If it is then plusnet will not deem it an issue.
