Speed dropped from 80MB to 59M
- Speed dropped from 80MB to 59M
20-10-2018 11:29 AM
I used to get 80MB on my fibre constantly but im only getting 59MB max at the moment after rebooting router and into master socket.
My estimated line speed profile is :
Estimated line speed:80Mb (This may vary between 67Mb and 80Mb) - Checked on 2017-12-18 23:19:50
Current line speed:57.8 Mb
Am I on the wrong profile or something?
hope you can help
Mike
Re: Speed dropped from 80MB to 59M
20-10-2018 12:09 PM
I'm afraid that there could be any number of reasons for the speed drop. As you will know, Plusnet people are usually in the Forum but they are a thin on the ground today. They may well pick this up. If they don't, or if you want to move things along, report as a fault.
To report a fault, run though the checks at https://www.plus.net/help/broadband/connection-troubleshooting/ and report a fault at https://www.plus.net/apps/kbdfaults It takes a bit of your time but costs you nothing, and makes Plusnet aware of your issue. They have to look at it, and the report gets the issue into the queue for action.
Please let us know how you get on.
21-10-2018 8:42 AM - edited 21-10-2018 8:46 AM
Hi @mikedoh,
I'm sorry that the speed that you're receiving at the moment is below the estimates for the line. I've tested your line and the test indicates that your line is currently banded to a maximum of 60mbps but it's not picking up any other issues. For reference, today's test result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 59.9 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 334.3 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-60M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-10-08T08:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 59.9 Mbps | 59.9 Mbps | 59.9 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 38.0 Sec | 900.0 Sec | 897.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-10-21T07:11:57Z | 2018-10-21T07:26:57Z |
Ingress Code Violation | 3 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I've requested that our suppliers reset the DLM which should remove the banding and increase your speed to within the line's estimates - this should be carried out within two working days. Please reboot your router if you've not seen an automatic increase in speed by midnight on Tuesday the 23rd. Let us know if this doesn't resolve the problem.
21-10-2018 7:13 PM
Thanks you Emily! Ill reboot my router every now and then
thanks for all the help and ill let you know how I get on.
