Speed dropped from 74Mbps to 62
- Re: Speed dropped from 74Mbps to 62
- « Previous
- Next »
24-07-2017 8:16 PM
I would say the line is banded at 74Mb
24-07-2017 9:39 PM - edited 24-07-2017 9:44 PM
Have to Agree with Browni if that max attainable is correct you should hit full Speed at the standard 6db no problem, i would ask for your Profile to be posted, download should say 0.128M - 80M
If the last part is lower than 80 your line is banded.
24-07-2017 10:14 PM - edited 24-07-2017 10:15 PM
I don't believe my line is banded - this is from before it re-synced with FastPath:
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off |
25-07-2017 10:20 AM
And exactly 24 hours later it has re-synced again and has now re-instated interleaving - I had no CRC errors over the past 24 hours so don't understand - my speed has also dropped back down?
SNR |
5.3 dB
7.5 dB
Line Attenuation |
5.7 dB
10.6 dB
Path Mode |
Interleaved
Interleaved
Interleave Depth |
2789
607
Data Rate |
61151 kbps
19998 kbps
MAX Rate |
101012 kbps
28710 kbps
25-07-2017 1:37 PM - edited 25-07-2017 1:37 PM
Can you keep this all to one thread rather than spread over 2 please? It just means we're having to reply to both each time. If we keep this to your own thread here that would be great: https://community.plus.net/t5/Fibre-Broadband/Sync-rate-suddenly-dropped-from-74-to-61-last-night/m-...
25-07-2017 1:45 PM
Sounds exactly like what happened when I tried out the DSL AC88U - when I connected my AC68U back up it resynced in the early hours of the morning on fastpath, but then resynced again on interleaved within 24 hours.
Could be that the short time of testing the new firmware kicked off a change in DLM which only came into effect after you'd switched back to the official firmware.
- « Previous
- Next »
