Speed dropped from 70 down to 15
- Re: Speed dropped from 70 down to 15
08-08-2020 4:00 PM
Hi, I've been having very unstable speeds for several weeks now. I'm on a fibre package for speeds up to 70 which was fine for a month or two and now it constantly hovers around 15-20.
Weirdly, my plusnet router also seems to drop out with an orange light around once a day for a few mins.
The BT Performance Tester is currently showing 13Mbps, and failed to run the additional tests for some reason
08-08-2020 4:04 PM
First thing I would check if there has gotten some noise on your landline, causing the speed drops.
You could also dial 17070 option 2 quiet line test which makes it easier to tell.
08-08-2020 4:32 PM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
10-08-2020 10:12 AM
This sounds remarkably familiar - my speed has gone through the floor in the last 2 weeks, and support don't really care
10-08-2020 9:58 PM
Mine too. Supposed to be 50Mb but has rarely got over 30Mb. In the last few days I'm lucky if I get over 10Mb.
13-08-2020 7:18 PM
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
