Speed drop tried everything help really appreciated
- Speed drop tried everything help really appreciate...
20-12-2018 8:19 PM
Re: Speed drop tried everything help really appreciated
21-12-2018 9:10 AM
Sorry to hear you're having issues.
Our testing hasn't identified any issues with your service. If you're still having issues please follow the steps below we can investigate further please connect your computer/laptop to the router with an ethernet cable and run the BT Speedtester service at http://speedtest.btwholesale.com
You must ensure that you have no other programs running at the same time such as streaming, general browsing and the most common one is antivirus programs downloading updates in the background. This must be done on a wired connection and not wireless Once the initial result is completed please click Further Diagnostics. Please type in your phone number and click run diagnostic test. This will run a test and send the results to the server for investigation
21-12-2018 9:41 AM
21-12-2018 11:39 AM
Hi @Chris35,
When it comes to Wi-Fi connections, I'm afraid we're unable to guarantee a minimum or consistent speed as there are simply too many different variables to take into consideration that we simply have no control over. This could range from the amount of other wireless devices in proximity of your own router which can cause signal interference or it could be down to the property itself, perhaps having older and thicker walls.
Because you're connecting solely via a Wi-Fi connections, I would recommend to try and change the wireless channel that your router is operating on to see if this helps to improve the wireless signal strength. We have a helpful video guide for step-by-step support in changing your wireless channel here.
1) To connect to your Hub One, you will need to open a browser and go to 192.168.1.254
If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Wireless.'
4) If this is the first time trying this, you can select the option to 'Refresh' at the bottom of the page which will force your router to rescan for the best channel for you.
5) If you are still having issues then you may wish to change the channels manually. To do this, repeat the above steps but select 'Advanced Settings' instead of 'Settings' and this will give you several other options.
6) Under 'Channel Selection' you will want to change this from Automatic to any one of the other channels and see if it improves your wireless. Give it 3-4 hours of testing to see if the issue still persists and change it again if you see no improvement. If you are having the same issue on 5 GHz wireless then you can also change the wireless channel under the subheading of '5 GHz Wireless'.
Any Wireless channel is prone to interference and can be caused by a number of factors, changing this channel will usually resolve the issue, if problems are still persisting after this then it is likely that something else is causing the issue. Further help can be found here.
21-12-2018 12:10 PM
21-12-2018 12:41 PM
Thanks for getting back to us with this information @Chris35. Given that this issue also occurred via an Ethernet connection, this may indeed be indicative of a fault intermittently cropping up on your line.
As we're not seeing any issues when testing your line at the moment and as the fault doesn't appear to be present from your end of things, there's not much further we can do to investigate further at this stage, but if you do experience any further problems, please let us know and we'll pick this back up for investigation as soon as possible.
21-12-2018 1:06 PM
21-12-2018 1:36 PM - edited 21-12-2018 1:42 PM
If the problem does persist, can you borrow a laptop from somewhere (neighbour)? If so, install dslStats on it and run it continuously. You might catch what's happening on that. I wouldn't mind betting that somewhere along the phone line, or maybe local to you, there is an intermittent source of electrical interference. If so, you should see bursts of errored seconds or worse on the output graphs. I had a problem which was caused by a neighbour's brand new high-frequency fluorescent fitting in a utility room. It wasn't switched on very often but when it was it did the trick!
Having said all that, I've just realised that dslStats might not be compatible with the PN modem. I'm not sure about that. Maybe someone could advise?
