Speed drop - reset required
grizedale
HI
I was warned by the engineer at my last speed drop that it would more than likely happen again and require another reset(see my post here https://community.plus.net/t5/Fibre-Broadband/Slower-over-time/m-p/1433390#M58986).  Well, it has happened again, work was being carried out at the box recently and consequently I am suffering a drop in speed.  Can I request an engineer to perform a reset at the box please?
Fixes: 380
Re: Speed drop - reset required
Testing your line is indeed showing your line speed is banded.
Sync Status In Sync
Downstream Speed 7.9 Mbps
Upstream Speed 1.1 Mbps
Profile Name 0.128M-8.8M Downstream, Interleaving High - 0.128M-10M Upstream, Error Protection Off
My tests aren't identifying the cause of that.
Description No problem found, OAM test is not currently supported on this line.
Voice Line Test Result Pass
As the line speed is falling below your estimates,
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
  High Low High
VDSL Range A (Clean) 16.5 11.4 1.8
I'd recommend reporting a fault here: http://faults.plus.net so we can arrange an engineer visit.
grizedale
I have carried out the fault test as requested.  Just one point, where is asks for interference on phone line, you need an option for 'Do not have a landline telephone'.  As I dont I have stated no fault on line.
Fixes: 380
Thanks for your feedback.
I've updated your fault ticket now, if you let us know once you've replied we can get this moving forward.
grizedale
Thank you, I have replied
Fixes: 380
That's booked in for you now, and I've updated your fault ticket too.
