Speed drop following migration from BT
- Speed drop following migration from BT
18-09-2018 9:54 AM
My connection speed has dropped from around 65 Mbps with BT to 46 Mbps, I did not expect a DLM reset to happen and assumed the change-over would not affect my speed.
I did have a phone line problem with BT which led to a DLM reset being required but this was over a month ago. I have checked changed all the usual things, filter, rj11 lead & router - no noise on the voice line either when calling 17070 and choosing quiet line test.
Any help or advice appreciated
Re: Speed drop following migration from BT
18-09-2018 6:06 PM
Sorry to hear this.
I've tested your line and that's not showing any cause but I can see the router was syncing higher.
During the first 48 hours I'm afraid we can't raise any faults for this but if the speeds are still poor after raise a fault here and we'll investigate further.
19-09-2018 8:57 AM
23-09-2018 7:26 AM - edited 23-09-2018 7:27 AM
I'm afraid this is quite normal as a DLM reset has occurred. I had just the same issue when I moved from BT and there have been a few posts on this over the recent months.
Assuming everything was healthy when you moved across, all you can do is let DLM do its "thing". Time scales are a pain(!), anything from a few days to, in my case 6 months, for speed to get back up.
My honest advice is simply to play the waiting came and not be frustrated by it
