Speed down from a stable 80/20 to an IP Profile change of 49/11
- Speed down from a stable 80/20 to an IP Profile ch...
- « Previous
- Next »
Re: Speed down from a stable 80/20 to an IP Profile change of 49/11
22-08-2015 4:58 PM
The firmware I compiled myself (OpenWrt) from trunk, and I've used the latest Lantiq drivers/firmware, which shouldn't be a problem.
22-08-2015 5:24 PM
25-08-2015 12:10 PM
25-08-2015 12:57 PM
25-08-2015 5:46 PM
He/she will come to the property and attach his portable tester to the master socket and test it from there.
If a reset is needed they'd have to contact the Openreach helpdesk to get this authorised.
In addition your issue isn't caused by DLM as your profile is "0.128M-60M Downstream, Error Protection Off - 0.128M-17M Upstream, Interleaving On" and your currently syncing at 49mbps.
From what I can see it looks more like a fault on the line.
25-08-2015 5:58 PM
I always thought it was DLM raising my SNR due to the disconnections, which in turn has lowered my sync speed.
Previous SNR was 6.xdB both ways
now it's 20.6dB down and 15.2dB up.
I've noticed this morning my line resynced at 5AM, on retrain it slightly raised my upstream from 12Mb/s to 15Mb/s however it's added some extra interleaving depth and a delay from 4ms to 8ms
SNR raised some more for the upstream, from 13dB to 15.2dB which doesn't make sense to me given the speed improved so it should have been lowered.
25-08-2015 7:11 PM
DLM doesn't touch the SNR margin - the target is always 6db.
25-08-2015 7:15 PM
Quote from: jsamuel Previous SNR was 6.xdB both ways
Is it possible these are line attenuation figures and not SNRM's?
25-08-2015 7:19 PM
DLM issues a change in target SNR if the line has dropped x amount of times the previous day. It thinks the line is unstable but in reality just a loss of power.
My attn is 8.9dB down & 10.2dB up
25-08-2015 7:23 PM
Quote from: jsamuel DLM issues a change in target SNR if the line has dropped x amount of times the previous day.
Nope.
25-08-2015 7:41 PM
Obviously if DLM sees the line as unstable it will first try to interleave, and if that doesn't work then banding which causes an SNR raise.
I think the confusion there is ADSL's DLM changes the SNR directly, where as VDSL's DLM uses banding.
25-08-2015 7:59 PM
Yes a banded speed can result in a higher actual SNRM, but the Target stays the same, just doesn't have any impact because of the banding.
26-08-2015 12:21 PM
26-08-2015 2:18 PM
Noise margin dropped significantly, and is still dropping hopefully to a normal level.
My ping appears to be 6ms now, a nice improvement from 20ms.
- « Previous
- Next »
