Speed down DOWN, Speed Up UP
dnpark38
I was 32/5 but today I'm 24/8 have reset router but makes no change.
BTW Performance is showing maximum of 25 Mb used to set at 36 MB out of the up to 38 Mb I pay for.
What is this all about please?
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
dnpark38
Re: Speed down DOWN, Speed Up UP
Still Down and Up today so a continuing fault not just a blip.
Fixes: 62
so have you raised a fault
dnpark38
Yes did that last night as no one from PN picked up on this post  yesterday.
dnpark38
OldJim
I believe you been in the Forums some time have ever heard of one down one up before?
dnpark38
Well this morning had a response from PN customer service to do a few things like Master Socket etc.
Then raise a Technical ticket if still a problem after 5 pm.*
Well after the use of master socket the Up returned to the normal 5 Mb
Usual        32-33/5
Fault          24/7-8
after tests  23-24/5
* Reason to wait until 5 pm. was because the BTW faults reporting was under maintenance until then today.
dnpark38
Back to normal this morning.
Will see what happens when the Internet gets busy.
