Speed down DOWN, Speed Up UP
- Re: Speed down DOWN, Speed Up UP
18-03-2016 2:17 PM
I was 32/5 but today I'm 24/8 have reset router but makes no change.
BTW Performance is showing maximum of 25 Mb used to set at 36 MB out of the up to 38 Mb I pay for.
What is this all about please?
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
Message 1 of 7
(1,081 Views)
6 REPLIES 6
19-03-2016 8:32 AM
Still Down and Up today so a continuing fault not just a blip.
Message 2 of 7
(501 Views)
19-03-2016 10:25 AM
so have you raised a fault
Message 3 of 7
(501 Views)
19-03-2016 10:28 AM
Yes did that last night as no one from PN picked up on this post yesterday.
Message 4 of 7
(501 Views)
19-03-2016 10:30 AM
OldJim
I believe you been in the Forums some time have ever heard of one down one up before?
Message 5 of 7
(501 Views)
19-03-2016 5:44 PM
Well this morning had a response from PN customer service to do a few things like Master Socket etc.
Then raise a Technical ticket if still a problem after 5 pm.*
Well after the use of master socket the Up returned to the normal 5 Mb
Usual 32-33/5
Fault 24/7-8
after tests 23-24/5
* Reason to wait until 5 pm. was because the BTW faults reporting was under maintenance until then today.
Usual 32-33/5
Fault 24/7-8
after tests 23-24/5
Message 6 of 7
(501 Views)
20-03-2016 8:25 AM
Message 7 of 7
(501 Views)
