Speed crashed again
jwsg
Speed crashed again
Two weeks in on a new DSLAM (I doubt with many other users) my speed test tonight is
 Download speed achieved during the test was - 28.87 Mbps
 For your connection, the acceptable range of speeds is 43.95 Mbps-62.79 Mbps .
 Additional Information:
 IP Profile for your line is - 62.79 Mbps
and its been much lower earlier tonight
My router stats are already 20% down from the first day
6. Data rate: 19999 / 64863
7. Maximum data rate: 25659 / 72304
8. Noise margin: 15.0 / 5.5
9. Line attenuation: 23.0 / 18.0
10. Signal attenuation: 22.9 / 18.
on a line that was estimated 67-80M (I'm 350m away)
Its been woe from the start - on the first day I was held back by the PN profile, then for a few days by the throughput drops 6pm-12pm which maybe have come back?
Looking for advice really - I could try another router resync or go ahead with a BT appointment - but if anyone from PN could run the diagnostics first - and maybe compare with those in the open ticket?
6 REPLIES 6
etdsaunders
Fixes: 7
Re: Speed crashed again
I've noticed tonight that my throughput is really low. Normally I get 72mb but tonight am getting around 51mb.
Sounds like you have a hint of congestion!
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs_Up
MatthewWheeler
Fixes: 479
The tests I've ran aren't showing a massive difference and there's no congestion issues on the SVLAN you're connected to.
 Matthew Wheeler
jwsg
Thanks for confirming there is no congestion now or any line fault, but as I measured it last evening file download speed actually went down to below 10M, then things (once again) completely cleared by rebooting the router later in the evening.
I was already disappointed by the sync speed dropping to 64 on a DSLAM that's only been enabled for two weeks but this loss of throughput isnt something I'd ever seen on ADSL
MatthewWheeler
Fixes: 479
Fibre can be more susceptible to crosstalk which can cause drops in speed.
A engineer would be able to confirm if there's anything that can be done.
 Matthew Wheeler
jwsg
Thanks for the info. I was worried because the sync is already down to 64 on a 2 week old DSLAM - how far below the 67-80 estimate will it eventually settle? I connected to a two socket faceplate even on a self-install.
The evening throughput is more severe but not constant or visible on the hub1 stats page and  more difficult for an engineer to advise as it happens after 6pm in line with other threads.
MatthewWheeler
Fixes: 479
Unfortunately I can't give a exact figure I'm afraid as everybody has a different experience with crosstalk.
Back when I was on Fibre my speeds dropped from 78 to 68 after my next door neighbour swapped over.
 Matthew Wheeler
