Speed consistently below guaranteed minimum
- Speed consistently below guaranteed minimum
09-10-2018 11:20 AM
My download speed is consistently below the guaranteed minimum. How do I get this resolved? Plusnet is so difficult to contact with no email support, the chat line seems permanently unavailable and the call centre painfully slow. My last call took 50 minutes to answer. Is there another way to contact them for support and service?
Re: Speed consistently below guaranteed minimum
09-10-2018 11:50 AM
The option that you are thinking of leaving always gets a quick response. I don't know whether they could help but may be worth a shot.
09-10-2018 2:58 PM
Is it wired speed that is always below minimum or wireless? If the latter, you won't get much from any ISP except to change the wireless channel to see if there is local wireless overlap. If wired speedtests show issues, then PN should do something, it will usually involve the BT speedtester as that logs the speeds and PN can gain the information direct. Try a speedtest at Thinkbroadband and see what the graph looks like: https://www.thinkbroadband.com/speedtest
Mark
09-10-2018 3:02 PM
I have found the problem, thank you. It is not Plusnet's fault after all. My so called gigabit connection to the router is not living up to its name. Sorry Plusnet.
09-10-2018 8:47 PM - edited 09-10-2018 8:49 PM
Hello @Alan_Hall,
Thanks for letting us know you found the problem. We forgive you , however if you do find an issue with connection please let us know.
