Speed capped
maddog56
Speed capped
Can someone look at my line profile. I still can't achieve more than 68Mbps.
Routerstats
Data rate: 20 Mbps / 68.508 Mbps
Maximum data rate: 23.043 Mbps / 82.374 Mbps
Noise margin: 6.0 / 6.0
Line attenuation: 4.7 / 14.3
Signal attenuation: 4.7 / 17.3
VLAN id:101
Upstream error control:Off
Downstream error control:Off
My IP profile from Openreach is currently
Down 66.13Mbps
Up 20Mbps
I have had no faults and my router has been left on hoping that the dlm will increase it but it still hasn't so i tried turning the router off leaving it for a bit then turning it back on and its still the same. Before this I was on the 55/10 profile and that took a couple of times to get removed, because the order wansnt done properly at plusnet.
7 REPLIES 7
EmilyD
Fixes: 117
Re: Speed capped
Hi @maddog56,
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
 Emily D
Mustrum
Fixes: 77
Re: Speed capped
Is that a fault? Is your line capable of more. The stats look OK.
Enter your number in the DSL checker and post the results, minus your phone number https://www.broadbandchecker.btwholesale.com/#/ADSL
maddog56
Re: Speed capped
Bt checker results
Terranova667
Fixes: 5
Re: Speed capped
the maximum available in the router stats being 82Mb is a sign the line can do more doesn't need the BTW checker to know that.
Mustrum
Fixes: 77
Re: Speed capped
Equally being 20Mbps above handback speeds means no one is going to investigate in the current climate.
Terranova667
Fixes: 5
Re: Speed capped
Not true, handback speeds have nothing to do with investigating a fault, they are for cancelling the service without penalty if Opnerech can't get the speed back above whatever your hand back level is.
Mustrum
Fixes: 77
Re: Speed capped
The BTW test today shows sync speed is now 74Mbps, I presume DLM has done its thing.
But even at 68Mbps a fault would be rejected by BTW/Openreach with leave it a few/days /weeks to let DLM do its thing.
The Max attainable speed is only a theoretical figure and can vary router by router.
