Speed Reduction
- Re: Speed Reduction
Speed Reduction
02-02-2018 8:22 PM
A fault was fixed with the phone line a week ago, since that the sync speed went from 35mbps to 25mbps. In the past 24 hours speeds have again reduced with speedtests showing anywhere between 5-8mbps down.
Any help with this matter would be greatly appreciated.
Re: Speed Reduction
02-02-2018 8:30 PM
Been having big problems with speed think plusnet are turning my speed down because the last two weeks I have had to download quite a lot finished now, but speed dropped from 72 to 28.
Re: Speed Reduction
02-02-2018 8:39 PM
Plusnet do not lower speeds you can download as much as you want hence why it's called fibre unlimited or unlimited extra, if you have issues then report a fault if you haven't already, you can do so here.. https://www.plus.net/apps/kbdfaults
