Speed Drops Every Week at Same Time !
- Re: Speed Drops Every Week at Same Time !
20-12-2016 12:27 PM
Every Saturday morning between 9-12 my fibre internet speed drops from 67mb to 25mb and would stay at that speed If I didn't reset the router (Hub One) . Once the router is reset the speed goes back up to 67mb and the fault disappears.
Only been on fibre for four weeks and this fault has been there the whole time. Before this I was on standard (17mb) broadband with PN and the line and speed was faultless.
I've tried using a different router (HomeHub 5) and changing wireless channels etc, and it shows the same fault. PN customer support have drawn a blank as well. They say there is no fault on the line and BT Openreach say the same !
Anyone have any ideas at all what could be causing this and any possible fixes ?
It's not a big deal having the reset the router once-per-week, but I'd prefer not to have to do this.
20-12-2016 1:14 PM
Welcome to the community forums @onlyme4.
Sorry to hear your speeds are dropping every week. When this happens is it only on wireless? If you haven't already, please could you test if it affects a wired connection also.
If it's regular ever week at the same time, it's possible it could be some sort of back up that's running, however if it was that I would have expected it to be the same back on ADSL as well
20-12-2016 8:00 PM
I must admit I hadn't considered checking if the speed also drops on a wired connection.
Will report back on Saturday with the findings.
In the meantime thanks for the suggestion and taking the time to respond.
21-12-2016 11:37 AM
No problem
Let us know how you get on on Saturday (Providing the speeds drop and don't do the typical thing of not breaking when you want them to for monitoring purposes) and I'll aim to get back to you some time next week
05-01-2017 12:55 PM
Well...its been a couple of weeks now and surprisingly, there has been no speed loss !
Whatever was causing my speed to drop at the same time every Saturday has either been resolved or managed to fix itself.
I'll continue to monitor the situation and report back if the fault come back after the Christmas break
Thanks.
09-01-2017 11:17 AM
Although admittedly I'm not sure what caused of fixed this issue, I'm glad to hear it now appears to be resolved.
Please do let us know if the problems return and we'll get that looked in to for you
