Speed Dropped
KaotiK
Speed Dropped
So my line has been consistent and synced at almost 29mb for a while... no problems. I had to shut off the power today, once done and router rebooted its now syncing at 24mb, Restarted router to see if that changed something but again at 24m.
Any reason for this? My line is capable of about 31mb synced, as i have had that before but i was happy with 29mb as my line has been spot on. So what can i do to resolve this drop?
cheers
Browni
Aspiring Hero
Fixes: 47
Re: Speed Dropped
Could be increased crosstalk on your line, what are your full router stats?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
KaotiK
Re: Speed Dropped
Not sure what crosstalk is
System Up Time 12:08:44
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoE 1837502 3365684 0 2607 12712 12:06:15
LAN1 1000M/Full 3031257 1607891 0 232796 161600 00:13:31
LAN2 Link down
LAN3 Link down
LAN4 Link down
WLAN b/g/n 600M 11569 3268 0 73 11 12:07:24
WLAN a/n/ac 1300M 347598 243571 0 9861 615 12:07:20
VDSL Link Downstream Upstream
Link Rate 24998 Kbps 6000 Kbps
Line Attenuation D0( 22.6) D1( 65.7) D2(N/A) dB U0( 8.9) U1( 52.4) U2(N/A) U3(N/A) U4(N/A) dB
Noise Margin D0( 7.7) D1( 7.6) D2(N/A) dB U0( 8.9) U1( 8.9) U2(N/A) U3(N/A) U4(N/A) dB
VDSL2 Profile Profile 17a
Are those the stats? My neighbour 3-4 doors down is getting 37mb he says, hes with BT.
Fixes: 167
Re: Speed Dropped
Sorry that your speeds are dropping.
It looks like your line is now in sync at 23.9, which is below the bottom end of the estimate. It is slightly about the Minimum Guaranteed Access Line speed.
Can you check for noise on the phone line (hissing, crackling etc) and ensure the router is in the master socket with no extension leads in place.
 Chris Parr
 Plusnet Staff
KaotiK
Re: Speed Dropped
No Noise on the phone, and yep its plugged into master socket. Just very strange as it been perfect and stable syncing at about 29mb for months.
KaotiK
Re: Speed Dropped
any help/update pleasE?
KaotiK
Re: Speed Dropped
Should i be raising a ticket? or is it something that can be sorted from here? should i restart my router again or will that make it worse?
rongtw
Fixes: 12
Re: Speed Dropped
You can start te troubleshooter here Thumbs Up  https://portal.plus.net/apps/kbdfaults
You will have to log in to member center
KaotiK
Re: Speed Dropped
Any plusnet stuff able to help here before i go ahead and start the troubleshooter? Left it a few days but speed is still low no change. cheers
Fixes: 541
Re: Speed Dropped
Apologies for the delayed response
From testing your line, it looks like your router in sync at 25mbps which unfortunately is right on your estimates of between 25mbps and 32mbps. Can you try plugging your router into test socket to see if that helps?
If you follow the link provided by rongtw you'll be able to raise a fault to us, however it's unlikely we'll be able to progress a fault with BT when your speed is within estimates. Sad
KaotiK
Re: Speed Dropped
I get this response, but what annoyes me about this is i have seen my line synced at 31mb before, its then also been constant and consistant at 29mb synced for ages... i get a drop due to turning the power off and it reboots and syncs at the 25mb.
So for me its frusrating because i KNOW my line is capable of more as ive had more the whole time, the bt engineer who came here and rewired everything with brand new stuff said the same thing that i should easily get 28mb-29mb sync speed minimum.
My neighbour literally 3 doors down gets 37mb as ive mentioned but hes with BT themselves.
What is the reason for it dropping? makes no sense to me if its capable of more. I have tried all the socket stuff, all my equipment, wiring etc is new. Heres a bt test!
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
  Download Speed
  23.46 Mbps
0 Mbps 24.17 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 23.46 Mbps
 For your connection, the acceptable range of speedsis 16.92 Mbps-24.17 Mbps .
 Additional Information:
 IP Profile for your line is - 24.17 Mbps
2. Upstream Test:  -provides background information.
  Upload Speed
  5.36 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 5.36Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Fixes: 541
Re: Speed Dropped
It's possible your neighbour is connected to a different copper pair, or the line takes a different route to the cabinet.
Whilst we appreciate the frustration caused, whilst the line speed/sync rate remains within the estimates, we won't be able to progress a fault I'm afraid.
Hopefully things pick up by themselves. However, if you notice the sync rate drop below the estimates shown at www.dslchecker.bt.com I'd recommend reporting the fault to us so we can raise this with BT.
KaotiK
Re: Speed Dropped
But then why was my line consistent at 29mb for so long? Something has happened for it to drop right? Why would that be? help me understand because it really is frustrating when i know its capable of more.
Fixes: 541
Re: Speed Dropped
It's possibly due to cross talk, which is basically other connections being added to the cabinet.
Or, somethings happened somewhere that's brought the speed down.
Unfortunately, as it's within estimates it's unlikely our suppliers will investigate. Sad
