Speed Drop
FIXED- Subscribe to RSS Feed
- Speed Drop
19-05-2016 7:20 PM
Since subscribing to fibre my download speed has been a fairly constant 18Mbps and upload about 2.25Mbps. However lately it has dropped to just under 14 Mbps download and 2.25Mbps upload. I called support yesterday and after running a few tests he said there was a fault in the copper wire side of the line.
He arranged a BT callout who came today - amazingly quick! However the BT engineer said there was no fault in the line. He then said I was getting 18 Mbps at the BT modem and it must be a fault with my router but after he had gone I connected my PC directly to the BT modem and still only got 14Mbps so it's not the router.
My PC has always been connected by cable as well as wifi. Anyone any ideas?
Fixed! Go to the fix.
Re: Speed Drop
19-05-2016 9:12 PM
What is the Plusnet Line Speed as shown here https://portal.plus.net/my.html?action=data_transfer_speed
Also what does the BTW Ip Profile say at speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do , just enter your phone number and do not change anything at the router even if the page says to.
Re: Speed Drop
20-05-2016 8:12 AM
Ok. The Plusnet line speed shows current speed 14.7Mbps. It also says there's no speed estimate currently held on the account.
The BTW Ip profile shows 22.66Mb for download with an actual reading of 13.67Mb and 10Mb for upload with an actual reading of 1.16Mb.
Hope that helps.
Re: Speed Drop
20-05-2016 8:53 AM - edited 20-05-2016 8:55 AM
Okay the key part is the Plusnet line speed. This is the limit that your download speed will work at. Hence why you are getting 14Mbps
So you need to phone/Chat with Plusnet and get them to increase then Plusnet Line Speed up towards the BT IP Profile. The Plusnet Line Speed should be just less than the BT IP Profile Download Speed.
Once PLusnet have increased this and you have verified it using the link given above, then you need to log onto the router, click "Disconnect", wait a minute and then click "connect" to get the new speed.
20-05-2016 12:42 PM
Many thanks SpendLessTime for your help. Have just spoken to support who admitted the line was capped but couldn't see the reason as it checked at 23Mbps.He said it was the accounts department who'd done it but couldn't give a reason.I can also now remember a similar occurrence when I was on ADSL. Very frustrating when they do it for no apparent reason and don't tell you they've done it either.
Re: Speed Drop
20-05-2016 1:05 PM
You're welcome.
