Speed Drop
rgraham
Speed Drop
Hope someone can help me, my line speed has dropped from a constant 78 meg to 63 meg recently.  I left it for a few days to see if it increased,but its remained at 63.  I ran a few test on BT Speed test site this morning.  Drop happened around the outage for plusnet a few weeks ago, and speaking to my other half she admitted that she switched off the modem a few times as she couldn't surf the web.
Can someone from the support team maybe have a look at my line please?
Regards
Roger.
Terranova667
Re: Speed Drop
yeah switching off the modem like that isn't great DLM will see it as a fault and impose restrictions until it thinks everything is ok again which can take time it's not uncommon to wait weeks for it to return to normal that's if there is no actual fault, I'm sure someone from the DCT will be able to see if a fault exists or if it's just DLM.
Re: Speed Drop
I recently had DLM drop me from (sync speeds) of 80 down to 72, as a result of the "standard" initial settings; a 10-20% drop seems typical from DLM intervention.
Other amounts of speed reduction are likely to come from crosstalk.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
