Speed Drop
- Re: Speed Drop
Speed Drop
21-07-2016 9:47 PM
Re: Speed Drop
22-07-2016 1:35 PM - edited 22-07-2016 1:36 PM
Re: Speed Drop
26-07-2016 1:45 PM
Re: Speed Drop
26-07-2016 1:52 PM
Hi dai, apologies for the delayed response.
Looking over your account, everything seems to be set correctly. I can see that the speed profile dropped around 3Mbps on 21/07/16 at 18:53, but a delta report on the 22/07/16 bumped this back up.
Re: Speed Drop
26-07-2016 2:30 PM
Re: Speed Drop
26-07-2016 2:35 PM
I've just checked back to your account and it does look like it needed a reconnect as the session was started prior to the speed going back up.
When I tested the connection earlier, this dropped it off, so it should be back up around 22Mbps when you get home now.
Re: Speed Drop
26-07-2016 2:39 PM
