Speed Drop
- Speed Drop
Speed Drop
23-05-2016 9:10 PM
Been noticing some issues with my connection so decided to do a check.
My current line speed is supposed to be 34.4Mb but a check on the BT Wholesale tool fluctuates between 18-21Mb.
Can someone please check my connection?
Thanks.
Re: Speed Drop
23-05-2016 9:46 PM
Hi @jeeman
Welcome to the forum.
You may find it faster if you go through the various guides starting with (although I note that you have done some of this already)
https://community.plus.net/t5/Fibre-Broadband/Fibre-Speed-Faults/m-p/1270253#U1270253
https://community.plus.net/t5/Library/Broadband-Faults-Guide-FTTC/ba-p/1322788
The forums aren't manned 24/7 by Plusnet staff so it may be awhile before it is seen and even then they may just ask you to go through the fault guides and log a fault.
Re: Speed Drop
24-05-2016 10:50 AM
