Speed Differences
RobS2
Speed Differences
Has anyone had a huge difference between the estimated speed and their actual speed.  I had my connection upgraded to fibre a week ago with an estimated speed of 80mbps.  The connection speed is changeable, but is typically around 1.8mbps, but does drop as low as 0.01mbps.
Just after some data points.....
Fixes: 62
Re: Speed Differences
what did the engineer say the speeds were
RobS2
I haven't seen an engineer.  Someone from OpenReach confirmed 1.8mbps as the sync speed.  The second person from OpenReach was able to diagnose my issue as a moving house problem.  By sitting in his van at the exchange he could tell that the house had moved by 300m over the last 7 days - I cant believe that the cable didn't break.  He then went on to say that PN had miss-sold the product and that he was telling the same story to lots of people - the line is long and the estimates are not reliable.
In typical PN fashion, a difficult problem requires a radical solution - "we can release you from your contract with no charge".
All am trying to understand is if this issue is typical or just affecting the people in the area where I live.
Fixes: 62
The BT man was being economical with the truth Plusnet take their figures from http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
It might be worth going to the address checker to see if that is different and looking at a few houses around
It would also be worth checking your cab and seeing if you can find it
RobS2
I'm about 2km from the cab, so suspect it is a BT estimation issue. Most of my neighbours have an estimated speed of 80mbps, although some a little closer have 16mbps as their speed estimates (taken from the DSL Checker).
However I am trying to find out whether the estimation errors are unusual?
