Speed Crashed this Morning, Line Check Please
- Re: Speed Crashed this Morning, Line Check Please
24-02-2016 11:53 AM
My speed down this morning seems to be 2.5 mbps It is normally 36Mbps day in day out. Up has dropped from 12Mbps to about 5Mbps.
Something is wrong, can you check my Connection please and let me know the results.
Thanks Dan
Thanks Dan
Message 1 of 4
(675 Views)
3 REPLIES 3
24-02-2016 12:02 PM
BTW Performance tester now showing 1.75Mpbs Down, and times out when I try to do further tests.
Message 2 of 4
(382 Views)
24-02-2016 2:30 PM
Speed has returned to normal.
Thanks for whatever you did, what caused it?
Can you still do a line check please.
Thanks.
Thanks.
Message 3 of 4
(382 Views)
25-02-2016 11:46 AM
Hi danludlow,
We've not done anything to your connection. I can see it has been dropping though so I'd just report a fault at http://faults.plus.net if that continues to be a problem.
Message 4 of 4
(382 Views)
