Speed 3 times below minimum
- Speed 3 times below minimum
05-06-2018 7:48 PM
Hi Plusnet,
I'm getting 20 Mbps downstream and 5.7 Mbps upstream. This is taken direct from the router interface + aligns with speed tests done over an ethernet cable.
I spoke to someone over chat and they said we had been banded down to 20 Mbps, we should be expecting a minimum of 60 Mbps+. They said they would sort this but I've seen no improvement since 25th May when speaking with support.
Could someone have a look into this?
Cheers.
Re: Speed 3 times below minimum
06-06-2018 9:23 AM
I've just tested your line and we're picking up on some connection drops and a potential issue with the line itself. This will be why the line has become banded.
Best to rule out the checks here next https://goo.gl/hcHRDv then report a fault over at http://faults.plus.net
Do keep us posted.
Adam
