Sorry, your auto login cannot be activated at this time.
FIXED- Subscribe to RSS Feed
- Sorry, your auto login cannot be activated at this...
08-10-2018 9:37 PM
I've tried for several days now to setup auto login connection but I keep getting the above "error", can someone please tell me if this is only me or have other people got this?
And if it's only me, how do I fix this please?
Fixed! Go to the fix.
Re: Sorry, your auto login cannot be activated at this time.
09-10-2018 1:20 PM
Hi @mexicano,
Thank you for getting in touch through the Community.
I am sorry to hear that you are experiencing issues. Could I ask, what auto login are you trying to set up? Is this for a WiFi connection on a particular device for example?
09-10-2018 9:09 PM
Hi Warwick,
I've attached a screenshot of what I am trying to do.
This will probably explain better.
10-10-2018 12:06 PM
Hi @mexicano
I've just tested auto-login and it's definitely up and running.
The facility to enable auto-login is based on your browser being able to store cookies, so I'd recommend clearing your browser cache and ensuring cookies is enabled. Also bear in mind that auto-login will only work on one device at a time, so if you have it active already on another device you'll need to disable it before activating it on another one.
In addition to the above, I'd also recommend trying different browsers/devices if your initial one fails.
Let us know how you get on
Best wishes
Dave
10-10-2018 1:44 PM
I use the latest Firefox browser and I cleared cache and cookies but I still got the same error message, BUT, after I disabled my adblocker add-on I was able to activate the auto login!!!
Now I'm searching for an adblocker that won't interfere like that.
So thanks for the help and quick replies.
10-10-2018 1:57 PM
No problem at all @mexicano, glad you got this sorted.
If there's anything else you need, just drop me a line.
Best wishes,
Dave
