Something happened overnight...
Browni
Aspiring Hero
Fixes: 60
Note the red lines either side of 3am
My Broadband Ping - Plusnet
I've been on a static IP address for a while and yesterday I was using gateway PCL-AG03 but that has changed to PTN-BNG01.
Have I been promoted to the new network?
2 REPLIES 2
MattyC
Fixes: 46
Re: Something happened overnight...
You haven't been migrated over to the new network yet.
I'm not certain about what happened, however there may have been a minor piece of planned engineering works going on, as you completely lost sync a couple of times. I wouldn't worry about it too much.
Browni
Aspiring Hero
Fixes: 60
Thanks Matty,
I was more curious if I had been moved to the new network than worried about the sync loss. Strangely enough my router is showing over 9 days DSL uptime so whatever happened wasn't local to me.
Thanks again mate.
