Someone is hogging my bandwidth
- Someone is hogging my bandwidth
30-10-2017 2:59 PM
Dear PlusNet,
I have ahad a few months of relative stability, but recent weeks I have seem my performance drop considerably. I have checked my side of things, updated firmware on router and modem, but not seeing the performance I should have. Methinks someone has moved onto a busy VLAN recently.
Can you take a peek for me please? Recent BT Speedtests performed.
Snufflewort
Re: Someone is hogging my bandwidth
30-10-2017 3:24 PM
Hi Snufflewort.
Line tests aren't flagging up any issues and the latest VP report isn't showing your circuit on an overutilised SVLAN.
If you're using a wired connection, I'd raise this to us at http://faults.plus.net so we can further investigate.
