Some websites don't work
Re: Some websites don't work
Hi Neil and welcome to the forums.
If you log in to your router and hit the disconnect button and then reconnect you should hop to a different gateway (it may take a couple of tries).
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
neilbradley
Thanks avatastic, all seems ok now.  Cheers.
Fixes: 21
Quote from: neilbradley
Im also experiencing the same issue, I can barely load any websites other than plus.net!
Not really on that this is now a known issue and there is nothing on the service status page.
Is it possible to get me moved to another gateway also please so I can make a payment on hsbc.co.uk?
my plus.net id is neilbradleyuk
Hi Neil, welcome to the forums also.
I totally agree with you about the lack of Service Status - You may have noticed my earlier post #7 suggesting one, and my comment reply #12 that one had not appeared, so I don't know what happened there as Matthew was going to try and get it done. Ho hum.
Anyway all seems sorted now and as far as I can tell and AFAIK pcl-ag03 is now working normally.
