Some devices connected with no internet; others fine.
FIXED- Subscribe to RSS Feed
- Some devices connected with no internet; others fi...
16-04-2021 11:15 AM
I have 7 devices connecting to my network - 5 WiFi & 2 LAN.
3 of the WiFi devices (2x Android phones & 1 Apple MacBook) do not have internet access, the other 2 do (Amazon FireStick & Windows laptop).
1 of the wired devices (PC) is connected to the internet, the other (Humax set top box) isn't.
This is all new, and all was working yesterday with no problems, and with no changes to the network by me.
Yes; I have rebooted the Hub One (x3)
Any suggestions?
Fixed! Go to the fix.
Re: Some devices connected with no internet; others fine.
16-04-2021 11:44 AM - edited 16-04-2021 11:46 AM
Ensure the 2 router frequencies/ SSID's have separate names.
Momentarily turn off wifi encryption/security; do those devices then work?
If so turn router wifi security back on, and double check devices security settings;
try using the router WPS button to remake connections.
16-04-2021 11:50 AM
This appears to be a wider issue https://downdetector.co.uk/status/plusnet/
16-04-2021 12:02 PM
There is a brief message with no detail in the Service Information area of the forum which says earlier problems have been resolved.
16-04-2021 12:16 PM
This now appears to be fixed, without me doing anything. Either it was a glitch at my end which resolved itself, or it has been repaired by Plusnet; in which case, thank you.
16-04-2021 12:20 PM
Thank you. I saw the message, but was still experiencing problems when I read it.
The post may have been referring to a different problem, or it may be that there was a delay before the fix made its way to my network. In either case, the issue seems to have been resolved.
