Solid Orange light, and b light
- Solid Orange light, and b light
30-03-2021 2:56 PM
So this morning connection was very weak, then it went out, so I restarted the router and then it happened. A solid orange light and orange b light.
Tried putting in my username and password didn't work.
Tried factory reset didn't work either.
When I put in my user name and password, and click connect, it doesn't connect. It says disconnected at the top.
Don't know if it's the router or problem with the connection.
Thank you pls help
Thank you pls help
Message 1 of 3
(237 Views)
2 REPLIES 2
Re: Solid Orange light, and b light
30-03-2021 4:59 PM
Unfortunately PlusNet people don't turn up here as often as they used to. I would run through the checks at https://www.plus.net/help/broadband/connection-troubleshooting/ and then ring in with a fault.
Message 2 of 3
(214 Views)
30-03-2021 8:05 PM
Thank you for your reply.
I rang them up and they said it was an outage in the area. It's fixed now.
Thank you for the reply though
Message 3 of 3
(199 Views)
