So what happend ?
rongtw
Fixes: 12
So what happend ?
noticed a step on my TBB  again , http://community.plus.net/forum/index.php/topic,143579.msg1265956.html#msg1265956 ; another increase in ping a weird step up ??  same again this morning 06.30
My Broadband Ping
Fixes: 149
Re: So what happend ?
It looks like low interleaving has been applied to your line.
Your profile is "0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off"
 Matthew Wheeler
Kevin
I think the same sort of thing has happened to me too.
http://www.thinkbroadband.com/ping/share/11cbe2798acf1aeee9d91161aee49c95-11-09-2015.html
Last time my ping was this high was when G.inp was applied to my line and before BT applied a fix to the HH5.
Matthew, could you let me have my profile please.
Kevin.
Fixes: 149
@Kevin
Your line currently has G.INP enabled.
"0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off"
 Matthew Wheeler
rongtw
Fixes: 12
@Mathew , Cheers for swift reply  Wink  but why was its applied i had a Good connection with a low Ping great for my games  Cool
Fixes: 149
@rongtw
DLM will have applied it to your line for a reason however I can't tell you exactly what I'm afraid.
The connection is stable so I'd assume it's down to errors on the line.
There's always the chance DLM will remove it in future but I can't promise anything.
 Matthew Wheeler
rongtw
Fixes: 12
Thanks Mathew  Wink
PS its nice to see PN staff more active here again  Cool
Kevin
Thanks Matthew.
I wonder what changed to double my latency time again?
Kevin.
