So Honey moon period starts
In last 10 mins went from
too
More than I was expecting considering how far I am from my cabinet, but my connection is literally 10 mins old.  This is with my billion 8800NL.
Line Coding (Trellis)	On	On
SNR Margin (dB) 6.2 6.2
Attenuation (dB) 25.6 0.0
Output Power (dBm) 12.1 2.0
Attainable Rate (Kbps) 35348 6595
Rate (Kbps) 35101 6515
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 167
Re: So Honey moon period starts
Not looking too bad at all Gus, let us know how it goes.
 Chris Parr
 Plusnet Staff
Just being nosey, how does it compare with your prediction from the BT Wholesale checker?
Call me 'w23'
@Gus how far are you from your cabinet?
3Mb FTTC
w23 just a bit faster, it says 30mbit on clean connection
godsell4 about half a mile as the crow flies, so my line to has to be a good bit longer
St3
Aspiring Champion
Fixes: 5
give it 5 months gus and you prob drop 12 meg like it did Tongue
Alucidnation
How come the test dates are not even close?
Alucidnation only 2 weeks apart, but anyway that was the last time I had done a test on TBBs site and it hadn't changed since that test till today
