Slowwwwwwwww fiber
pantsman28
Slowwwwwwwww fiber
I am sat virtually on my exchange but the speed on fiber is beyond poor, over the past 2 weeks.
Exchange code: WMSTJ St Johns.
Can someone check it over please. Loads of noise on the line
Tonight has been basically a waste of time...  last speed speed check was 21mb going to monitor it.
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/04ff7dc68d33900f89eee8269f201a96.html"><img alt="My Broadband Ping - poor" src="http://www.thinkbroadband.com/ping/share-large/04ff7dc68d33900f89eee8269f201a96.png" /></a>
[url=http://www.thinkbroadband.com/ping/share/04ff7dc68d33900f89eee8269f201a96.html]My Broadband Ping[/url]
SpendLessTime
Aspiring Hero
Fixes: 80
Re: Slowwwwwwwww fiber
If you have loads of line noise, then a fault needs to be logged with your telephone line rental provider.
If that is Plusnet then use the Phone Troublsehooter at http://portal.plus.net/my-account/tools/phone-troubleshooter
Don't mention problems with FTTC, just get the noise fixed on the phone first.
pantsman28
does seem to be a problem with the line...... whats the bt speedcheck? cant find the url ? cheers
pantsman28
found it.
http://speedtest.btwholesale.com/
15 minutes for support on a broken line, crackling constantly. ping latency 72.13ms, download speed 62.12 mb, upload 0.20 mbps
Fixes: 62
pantsman28
how can you report a problem without having to phone someone? can't you just create a support ticket any more?
Fixes: 62
see the first reply to your opening post
Plusnet Staff
Plusnet Staff
Fixes: 117
I'm sorry that you're experiencing problems with your service. I've tested your line and have found no fault, however we need to get the noise looked into as it's likely to be the cause of your speed fault. I've opened a ticket on your account with a few checks you can do before we arrange an engineer appointment to investigate further.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
pantsman28
thanks for opening the support ticket. Screen shot of super fast internet (NOT) Monitoring in progress
