Slower than expected speeds
challii
Having just swapped out a speedtouch router to a TP-LINK TD-W9970 and was shocked to see my connection speeds.
DSL
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/L
  Upstream Downstream
Current Rate (Kbps) 11742 46555
Max Rate (Kbps) 11869 45974
SNR Margin (dB) 6.1 6.3
Line Attenuation (dB) 19 8.7
Errors (Pkts) 0 0
BT Wholesale Perfomance Checker Reports
 Download speedachieved during the test was - 42.98 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-45.06 Mbps .
 Additional Information:
 IP Profile for your line is - 45.06 Mbps
Apparently according to BT I should be getting:
Telephone Number xxxxxxxxxx on Exchange WITHAM is served by Cabinet 14
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 62.1 20 20 -- Available -- --
VDSL Range B (Impacted) 69.1 40 20 10.6 -- Available -- --
Is there anything I have missed?
Router is connected directly to the master socket, there are no extensions.
1 REPLY
SpendLessTime
Aspiring Hero
Fixes: 82
Re: Slower than expected speeds
@challii
As the speeds are well below the estimates then it is worthwhile checking for a fault and log one if necessary.
But test the phone first and then if necessary the broadband. Links below.
First thing is to check for a phone fault (if Plusnet provide the phone start here https://www.plus.net/help/phone/phone-line-troubleshooting/ ) If you do have a phone voice fault, report it as such and do not mention any broadband issues. And then when that is fixed, see if the broadband is better.
Then if still not solved (or no phone fault is in evidence) start with the FTTC guides at https://community.plus.net/t5/Fibre-Broadband/Fibre-Fault-Guides/m-p/1156188#U1156188
