Slower fibre speeds :(
- Slower fibre speeds :(
on 08-04-2019 5:55 PM - last edited on 08-04-2019 6:24 PM by Strat
Hi I switched to Plusnet today but my speed has dropped a lot. I was getting the full 80 Mbps with TalkTalk but now I’ve switched I’m only getting 64 Mbps.
Will my speed increase do you think?
Product name: BT Hub 6A
Serial number: [Removed]
Firmware version: SG4B1000B540
Firmware updated: 21-Mar-2019
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 9 Hours 16 Minutes 3 Seconds
Data rate: 20.00 Mbps / 64.06 Mbps
Maximum data rate: 27899 / 78974
Noise margin: 15.3 dB / 6.3 dB
Line attenuation: 15.4 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 7168 MB Uploaded / 19394 MB Downloaded
Broadband username: [Removed]@plusdsl.net
BT Wi-fi: Active
2.4 GHz wireless network name: BTHub6-XFK9
2.4 GHz wireless channel: Smart (Channel 6)
5 GHz wireless network name: BTHub6-XFK9
5 GHz wireless channel: Smart (Channel 36)
Wireless security: WPA2 (Recommended)
Wireless mode:
Moderator's note by Dick (Strat): Personal information removed from a public forum.
Re: Slower fibre speeds :(
08-04-2019 6:04 PM
Hi there @thomasmortin18,
Thanks for getting in touch with us.
When your service goes live your router and line have a 10 day training period. During this time your speed will behave erratically while the line settles. Toward the back end of the 10 days you should start to see the speeds quoted at sign up. If you are still experiencing issues after the 10 days have finished please get back in touch so we can investigate further.
Thank you.
13-04-2019 2:41 PM
Sync speed seems to be increasing
On fibre is it possible to request a 3DB SNR profile?
I believe that would get me upto the full 80
name: BT Hub 6A
Serial number: +084316+NQ90232977
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 12 Hours 5 Minutes 48 Seconds
Data rate: 20.00 Mbps / 78.87 Mbps
Maximum data rate: 26447 / 79678
Noise margin: 15.1 dB / 5.2 dB
Line attenuation: 15.6 dB
Signal attenuation:
VPI / VCI: 0/38
Data sent / received: 9232 MB Uploaded / 6119 MB Downloaded
Broadband username: @plusdsl.net
BT Wi-fi: Active
2.4 GHz wireless channel: Smart (Channel 1)
5 GHz wireless channel: Smart (Channel 44)
Wireless mode: Mode 1
Firewall: On
13-04-2019 4:18 PM
It is already set at 3dB, though yours hasn't got there yet
A possible reason is the short uptime of 12 Hours 5 Minutes 48 Seconds
(if you're restarting the router then that might be the reason)
It might be worth waiting for a member of staff to check if there's a line issue.
13-04-2019 9:46 PM
Hi @thomasmortin18, I've tested your line which shows you to currently be in sync at 74.9mb, which is within estimates.
I'm afraid on Fibre we can't request 3dB, if you have any further queries please just get back to us.
