Slower Speed
- Slower Speed
Slower Speed
25-05-2015 7:54 AM
Hi
I had fibre installed last week and due to the plusnet router not turning up (still waiting after 2 x weeks?) I have had to plug into an old Billion 7800n, the speeds the engineer got were 37 and 17 although I can now only achieve 25 and 10, the connection also seems a bit erratic and when streamong radio it keeps dropping out, is this to do with the router I am using, line issues or something else please?
Message 1 of 2
(468 Views)
1 REPLY 1
Re: Slower Speed
25-05-2015 1:04 PM
The connection seems stable from what I can see.
However the sync speeds are below your estimate of 38mbps.
I'd recommend raising a fault using the link below
https://faults.plus.net
Message 2 of 2
(256 Views)
