Slower And Slower Upload Speed
- Slower And Slower Upload Speed
10-08-2018 10:33 PM
My upload speed seems to be getting slower and slower the past couple of months. It used to be around 7mbps now its 1.98mbps. Download speed seems fine and stable at around 47mbps and on a 3db snr profile. Can anyone check to see why? Many thanks.
Re: Slower And Slower Upload Speed
11-08-2018 1:15 PM
Sorry you're having problems.
I've tested your connection and the upstream sync is very low for your line at 2meg (the estimates are minimum 4.8meg, maximum 8.9meg).
Part of the testing process tries to detect any possible interference and over a period of 14 days regular interference is being detected by the testing, in my experience this could be mean nothing but it could also be an indication of an issue.
3db can also cause problems on connections, but it isn't affecting your downstream sync or throughput so initially going through the process of resetting the line, which can be a chore on FTTC connections, is probably not worth it at this early stage.
At the moment I think the best solution is a process of elimination. So I'd like to test the connection with all the internal wiring isolated to make sure this isn't causing your issues. If possible can you confirm your internal setup to make sure something internally isn't causing the upstream sync drop.
The easiest way to do this is to unplug all devices and wiring from sockets relating from your telephone number and plugging your router directly into the test socket. The test socket is found behind the faceplate of your master socket. Please let us know if you need any advice locating your master socket, or the test socket.
Once it's plugged into the test socket can you let us know so we can retest it to see if this changes the sync results - Joe
12-08-2018 4:13 PM
Connected as above. Modem direct into test socket and everything else disconnected. Thanks.
12-08-2018 8:07 PM
a couple of screenshots from dlstats
13-08-2018 12:15 PM
Hi there, in order to investigate this further and look into your account I have raised a ticket on the account since we are now dealing with account specific information. You can view and respond to the ticket here.
15-08-2018 10:56 AM
15-08-2018 3:07 PM
Hi @Twister1264
My apologies that nobody booked this in for you - we don't actively track open faults tickets within the social media team, so its likely that my colleague was unaware that you'd responded until your prompt today.
Unfortunately, it won't be possible to book an appointment for today as all engineers are allocated at least 24 hours in advance.
If you could provide further availability on your fault ticket here and then respond to this thread to indicate that you've done so, I'll make sure this is booked as a priority.
Best wishes,
Dave
15-08-2018 3:48 PM
Ticket now updated with another date. Thanks
15-08-2018 7:08 PM
Hi there, than you for the update. I have just updated your ticket with the booked appointment, you can review the ticket by clicking here.
