Slow upload line capped?
- Re: Slow upload line capped?
26-05-2021 2:17 PM
Hi, my line has slow upload for a few months now. It seems to be capped at 0.8mbit and attainable is around 1.6mbit. The upload speed never changes.
Is there anything that can be done to improve this? Download speed is excellent 26-28mbit
Tom
26-05-2021 7:24 PM
Hi @digit101
Hope you're doing well, thank you for reaching out via our Community Forum regarding your broadband speeds, particularly your upload speed.
I've done some checks and can see that although the broadband was provisioned correctly, for an unknown reason, your upload speed has been capped at 0.8Mbps. the line also appears to be incorrectly banded at a maximum download speed of 35Mbps. This is not having a large effect on your download speed however, which is coming in at 27Mbnps, within the estimated range.
I've now raised a fault with our suppliers to investigate the issues surrounding your upload speed. Our technical Support Team will review this within the next few days and will provide a further update from their end.
If you're interested, I've popped our GEA test results in this post for your reference.
26-05-2021 8:39 PM
Hi Tom,
Just to follow up I've arranged for your line to be reset which should lift the banding and cap on the upload speed.
This would've been placed automatically by the software at the cabinet (the green box in the road) normally if there's an underlying issue but line tests aren't showing the cause for this.
If your upload speed doesn't improve after 3 working days or there are further issues, we'd likely need to arrange an engineer visit to investigate further.
We'll get back to you via the ticket 214687413 that Adam's raised on your account as soon as we know more but feel free to post back here to let us know how it goes.
