Slow unlimited fibre
- Re: Slow unlimited fibre
24-02-2015 2:12 PM
When I first had it installed I was getting 70/20 even though now they say my line will support 60/20.
I've tried numerous routers currently running a new Asus RT-AC66 which seems very stable.
24-02-2015 2:18 PM
Download speedachieved during the test was - 28.28 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-29.04 Mbps .
Additional Information:
IP Profile for your line is - 29.04 Mbps
Upload speed achieved during the test was - 4.93Mbps
24-02-2015 2:49 PM
First installed was getting 65-68 Mbps, then recently the problems started and I've seen it drop from 65/68 download to 55, 50, 48, 45, 40, 38, 32 and that's where it is currently.
Very unhappy.
24-02-2015 2:55 PM
24-02-2015 3:00 PM
24-02-2015 3:09 PM
This is on a wired connection using Openreach Modem & Plusnet router, I'm using short cat6 cabling and the problem persist even whilst connected directly to the Openreach modem of which I have two different models as the BT Openreach engineer left me a spare. The engineer also replaced the spool of cable from the pole to my property.
Between January 2014 to January 2015 I got 76 down and 19 up without any fluctuations. So my line is more than capable of achieving 76/19 as it did so or an entire year since signing up.
I have a feeling that the exchanges and PTP cabinets are being overloaded with too many connections.
Check out my thread below:
http://community.plus.net/forum/index.php/topic,136493.0.html
24-02-2015 5:00 PM
24-02-2015 5:07 PM
24-02-2015 5:09 PM
24-02-2015 5:15 PM
24-02-2015 10:08 PM
Quote from: ohdaesu I have done, apparently the line has been fixed and should be upto full speed, but it is not
I've been told the same thing by Plusnet about the same issue.
