Slow speeds
Keystroke
Slow speeds
Hi all I normally have high 70+ download speed and at least a 20 upload however for the last few days I have been experiencing any help would be appreciated.
*EDIT* Seems to be a problem with the killer network manager on my pc. Turned it off and back at my usual speeds.
sjptd
Re: Slow speeds
Seems to be a problem with the killer network manager on my pc.  Could you tell us which one that was, so others can avoid it?  Thanks.  Or was it just that you forgot to make some setting on it and it was behaving 'properly'?
Keystroke
Re: Slow speeds
Yeah sorry somehow bandwidth control had enabled and was limiting my speeds. I just disable it from the network settings menu in the killer network manager.
dick:quote
