Slow speeds and disconnects again
caldersey
I'm on the 80/20 connection and originally had speeds of 35/10 and regulation disconnects. A fault was detected and it took three engineers to fix the problem (the first two failed to) but my speeds went to 70/15 and the disconnects stopped.
Now, a little over a week later, my speeds have dropped to 25/12 and the disconnects have started again.
This is getting tedious now, can any PN employee explain why this is happening?
ginourie
Re: Slow speeds and disconnects again
I have also been getting disconnected every few hours which is really annoying. It has only really been this week that i have noticed it though. im on the 38/2. but speeds have been dropping since the disconnects started happening.
SpendLessTime
Aspiring Hero
Fixes: 67
caldersey
The disconnects don't coincide with uploads and it doesn't explain why my speeds has dropped from 70mb to 25mb.
ginourie
Same unfortunately. I have been checking router logs and it has been disconnecting while I have been at work and practically nothing is using the internet.
I also had an enginner come round today to check the line and everything seemed fine to him, he even fitted 1 of them master sockets with the filters built into them.
caldersey
Internet is virtually unusable today, disconnects every few minutes.
