Slow speed
dragon123
Slow speed
My broadband speed has dropped to 20mb for the past couple of weeks when previously I was getting around 50mb. Could someone from support check this please? Thanks.
Fixes: 136
Re: Slow speed
Our tests are showing a external issue so we've raised this to our suppliers.
 Matthew Wheeler
matthews
Re: Slow speed
@MatthewWheeler we're also experiencing significant slowdown and high latency.
Please Note that I'm not posting about my own connection, so can you look at the IP of this post rather than the username associated with it please. If you need any form of authorisation let me know.
Fixes: 136
Re: Slow speed
@matthews Our tests aren't showing any issues and your ping graph isn't showing any obvious issues.
By slowdowns are you referring to speedtests or just general browsing?
 Matthew Wheeler
matthews
Re: Slow speed
@MatthewWheeler Thanks for the response. General browsing is slow, with latency for pretty much every web request showing as >100ms. The graph looks very off as far as I'm concerned, as it normally looks like this one (from my own connection which is working fine).
The problems seem to start yesterday morning, was cleared up by yesterday lunchtime but then have re-started now and are still going.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Slow speed
The graph further up can often be seen if the connection is being using a lot, when the problem is occurring can you provide a tracert to somewhere like bbc.co.uk so we can see the increase in latency?
 Chris Parr
 Plusnet Staff
