Slow speed?
- Slow speed?
Slow speed?
31-07-2016 8:39 PM
Hi, for the past few weeks we have experienced very slow Internet speeds, even Google won't load and times out. Can anyone check what's happening here? Has our speed been cut? It is unusable sometimes. Thanks
Message 1 of 2
(324 Views)
1 REPLY 1
Re: Slow speed?
01-08-2016 11:22 AM
Testing your line isn't showing any problems at all, it's stable and the sync speeds look good.
Are you connected on wired or wireless? What results do you get on a BT Speedtest? http://speedtest.btwholesale.com/
Message 2 of 2
(298 Views)
