Slow speed
run187
Slow speed
My speed has been halved in under a month gone from like 38 meg to 18
Could someone see what the issue is ,all im told is a engineer will need to visit and when they do they find no fault and im
Told via the email this could cost me money ..
Fixes: 21
Re: Slow speed
Can you run the BTw Diagnostic Speedtest and post the IP Profiles from the results please?
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Slow speed
The line isn't showing any faults when it's being tested, but it is syncing below the estimates. The next step is to get an engineer visit arrange, the £50 is only applicable if the issue is caused by something in your premises or if you miss the appointment.
Sync Status In Sync
Downstream Speed 20.5 Mbps
Upstream Speed
6.0 Mbps
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 40 29.4 7.7 5.6 -- Available -- --
 Chris Parr
 Plusnet Staff
run187
Re: Slow speed
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Slow speed
That would match with the test I performed. We need you to reply to the open fault ticket on your account with the availability for an engineer visit.
 Chris Parr
 Plusnet Staff
run187
Re: Slow speed
ok tx..
