Slow speed
wolfheart
Slow speed
14 REPLIES 14
Fixes: 75
Re: Slow speed
@wolfheart,
The link you've posted is a tad broken but these are the results you got (for anyone viewing this thread).
From the testing I've done everything looks like it should be performing as expected (mid-high 70s speed).
I'm just wondering if your router is setup correctly. I can see you use your own router, an ASUS I believe. Is this configured to connect to Fibre, and not ADSL?
It might be useful to provide details of the router make and model so we can direct a little easier should we need to.
 Joe
wolfheart
Re: Slow speed
The router is an Asus rc-ac66u
wolfheart
Re: Slow speed
Also we are being hacked and they are doing denial of service attacks etc. As you can see from my output in linux you will see 2 android boxes (we do not have any android boxes). As for the 169.254.0 i am suspicious.
Re: Slow speed
@wolfheart Do the anbox0 interfaces not belong to an anbox android emulator installed on your machine?
wolfheart
Re: Slow speed
No I do not have any android software including emulators etc installed.
Fixes: 101
Re: Slow speed
@wolfheart I assume that's a typo and you mean an rt-a66u. In which case you must have a modem as well somewhere because that's a cable router ?
@JOLO I'd be pretty sure that if you configure a modem or router explicitly for ADSL only on a Fibre enabled line then it won't sync, unless of course the ADSL jumpers have been left in at the exchange(unlikely). Are we sure the line is a Fibre line ? those speed figures look remarkably like ADSL ones to me!
The sync details from the modem would be useful
wolfheart
Re: Slow speed
Hi ,
Yes it was a typo and its setup for ADSL.
wolfheart
Re: Slow speed
I forgot to mention the ASUS Rr-66u IS A router is connected to the Plus Net modem what my dad got when he signed up.
Fixes: 101
Re: Slow speed
If it's an rt-66u then there is no setting for ADSL or Fibre, there's only the PPPoE settings. Any ADSL or Fibre setting will be in the modem. What make/model is the modem ?
@JOLO if this really is a Fibre line , could you do a GEA test please ?
Fixes: 56
Re: Slow speed
@MisterW - GEA test shows Fibre sync speeds
est OutcomePass
Test Outcome CodeGTC_FTTC_SERVICE_0000
DescriptionGEA service test completed and no fault found .
Main Fault LocationOK
Sync StatusIn Sync
Downstream Speed73.6 Mbps
Upstream Speed20.0 Mbps
Appointment RequiredN
Fault Report AdvisedN
NTE Power StatusPowerOn
Voice Line Test ResultPass
Bridge TapNot Detected
Radio Frequency IngressNot Detected
Repetitive Electrical Impulse NoiseNot Detected
Cross TalkNot Detected
Estimated Line Length In Metres434.6
Upstream Rate AssessmentVery Good
Downstream Rate AssessmentGood
Interference PatternNot Detected
Service ImpactNo Impact Observed
Home Wiring ProblemNot Detected
Downstream Policing Discard Rate0.0
Customer Traffic LevelUpstream and Downstream Traffic Detected
TechnologyVDSL
Profile Name0.128M-80M Downstream 3dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Thanks,
MoR
 MoR
Fixes: 101
Re: Slow speed
Thanks @MasterOfReality , is there any possibility that we're looking at different accounts somewhere? The OP's posted speeds look VERY ADSLish
wolfheart
Re: Slow speed
I I believe the modem is an BT OPEN REACH, I will have to check model etc... Also I tried connecting the the internet with the password (broadband) that is now in my brother Mark's account ant I keep getting an error saying check with isp about problem with dhcp.
wolfheart
Re: Slow speed
I only wanted to lock the connection down and lock the network to i.p.s instead of random. and make it more secure and plan on using a firewall like smoothwall or one on Arch Linux. Also next week I plan on getting the following and does it work with plus net and also do you have the settings for it please as my dog has broke the antennas on the rc-ac66u and I want to upgrade anyway as had this old router a while now anyway below is what I want to get  :-
Fixes: 754
Re: Slow speed
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
