Slow speed new customer
- Slow speed new customer
on 17-03-2019 6:06 AM - last edited on 17-03-2019 11:43 AM by Strat
Hi. Recently signed up to PN Tuesday this week. Speed estimate was approx 25 to 35. Min of 22.4. However now it seems to have settled at about 11. I've done 2 BT tests and one states that my IP profile is only 12mb. I've attached some screen shots for the plusnet experts to peruse. So far I haven't wired up with ethernet. Cheers. Paul
Moderator's note by Dick (Strat): Phone number removed from a public forum (to an area that staff can see).
Re: Slow speed new customer
on 17-03-2019 6:07 AM - last edited on 17-03-2019 11:43 AM by Strat
2nd attachement
18-03-2019 9:34 AM
I'm sorry you're having problems with your speed. I've run some tests on your connection and it's clear there's an issue somewhere.
Your estimates are as detailed above, and your minimum guaranteed speed is 22.4Mbps but the router is only syncing at 12.8Mbps which is why your throughput is low.
I think this is probably going to need a fault raising on your service, but before we go down this route would it be possible to confirm and describe the setup you currently have? Is the router plugged directly into the main master socket (if not can you do this and let us know so we can retest), any extensions?
If you could provide a picture of the router setup and location that might be useful, if not a description is fine.
18-03-2019 9:48 AM
18-03-2019 7:41 PM - edited 18-03-2019 7:45 PM
19-03-2019 9:22 AM
Thanks @Dirkdiggler
If you unscrew the bottom part of that faceplate, the test socket is underneath in the bottom right.
If you could try the router directly into that test socket (you'll need the microfilter that was in the box with the router) and let us know what the results of a wired speed test are, that would be great.
Best wishes
Dave
21-03-2019 8:27 PM
22-03-2019 9:34 AM
Thanks for getting back to us.
So we can investigate further I'd recommend raising a fault here and posting back once you've done so.
This will allow us to get this picked up straight away
22-03-2019 6:31 PM
23-03-2019 7:43 AM
Thanks for getting back to us @Dirkdiggler.
Due to scheduled Openreach maintenance on their faults diagnostic services, we're unable to raise the fault until around 17:00 this afternoon when the maintenance completes.
I've noted down your account and you'll receive ticket notification between 17:00 and 18:00 this evening with further information on when we can expect the issue to be resolved or of any next steps.
Please accept my sincere apologies for the delay.
27-03-2019 8:46 AM
27-03-2019 10:29 AM
Hey @Dirkdiggler
Thanks for letting us know.
I have now updated your ongoing ticket with further information. You can view the ticket here.
Thank you.
02-04-2019 11:45 AM
02-04-2019 12:51 PM
youll get there in the end typical engineers who dont want to do anything but eventually u will get a decent one who actually does something and fix the problem hes talking rusbbish just didnt want to do anything request plusnet to get another engineer out to you ......god enginners are so bone idle and lazy well some of them
02-04-2019 3:04 PM
Hi @Dirkdiggler, I'm sorry to hear the engineer doesn't seem to have given much explanation or support regarding your speeds. I can confirm however and have done via a ticket on your account the engineer looks to have got to the bottom of the reason behind your lower than expected speeds.
The ticket I've updated on your account and ongoing fault can be found here
The graph which shows the comparison between distance to cabinet and speeds can be seen below. ( Your conenction being VDSL2)
Please drop us a ticket on here when updating the ticket on your account and we'll happily get this picked up for you.
