Slow peak time speeds Leigh on Sea Exchange
- Re: Slow peak time speeds Leigh on Sea Exchange
17-04-2016 2:06 PM
Hi
I am on 40/2 FTTC. Currently getting 35/2 sync speeds. If I do a speedtest at offpeak time I get around 31mbps download speed. If I do the same during peak times (early evening is the worst) I get down to around 3mbps to 9mbps. This has been verified over multiple weeks. Download speeds are low either downloading files or torrenting and connecting or disconnecting to a VPN makes no noticeable difference. I have tried changing gateways - little difference, currently on pcl-ag01. I am on the Leigh on Sea exchange, cabinet 15. Also can I have a DLM reset to remove my banding, 62 days uptime and still banded.
17-04-2016 10:49 PM
Hopefully plusnet pick this topic up tomorrow and check for congestion.
If you Like it, give it a
18-04-2016 7:07 PM
Still no response from plusnet.
18-04-2016 11:02 PM
35mb on this package is normal speeds iirc and they won't change unless you upgrade of course.
