Slow internet
- Slow internet
Slow internet
21-03-2020 1:03 PM
I have been with
plusnet some months i have a Plusnet Hub One router. I use a Speed Checker and have found that speeds on average are
ping 16ms
download 19.58 mbps
upload 8.81 mbps but today it is
ping 164ms
download 7 mbps
upload 8.6 mbps
These results are not good, what can i do to improve them if anything. i also loose signal occasionally i.e. router shows orange etc
Re: Slow internet
30-03-2020 12:04 PM - edited 30-03-2020 12:05 PM
Hi @bazzaman,
I'm sorry that your connection is poor and for the delay in getting back to you on here. I've tested your line and can see that it's currently syncing at 5.9mbps, which is significantly below your estimated speed of 38 - 40mbps. However, the test hasn't picked up the cause of this from here:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 5.9 Mbps | ||||
Upstream Speed | 10.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 429.8 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream traffic detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
DP Type | External | ||||
Profile Name | 0.128M-30M Downstream, Retransmission High - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2020-03-17T12:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 6.2 Mbps | 29.9 Mbps | 29.5 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 614.0 Sec | 900.0 Sec | 899.2 Sec |
Retrains | 0.0 | 9.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-03-30T10:20:46Z | 2020-03-30T10:35:46Z |
Ingress Code Violation | 1 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
As the test hasn't picked up the cause of this from here, we'll need to do some troubleshooting to start ruling things out. I'd recommend starting with basic checks here. If these checks don't resolve the problem, the next step would be to connect your router directly to the test socket, which is under the faceplate of your master socket and seeing if the connection stabilises. This rules out internal wiring, face plates and extension sockets as being the cause. Please see the following guide for instructions on how to connect to the test socket. https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Please let us know if this doesn't resolve the problem.
Re: Slow internet
30-03-2020 12:32 PM
Re: Slow internet
30-03-2020 12:51 PM - edited 30-03-2020 12:53 PM
In addition to my previous post. I have changed the cable from master skt to router and switched router off for a few minutes. Speed is now 16 mbps but still far from ‘normal’
Re: Slow internet
02-04-2020 3:31 PM
What can we try next ?
Re: Slow internet
13-04-2020 6:30 PM
this just isn't good enough !!!!!!!
Re: Slow internet
13-04-2020 7:58 PM
Mmm, I had a previous problem which was supposedly being handled by EmilyD. I hope that she's OK.
Re: Slow internet
17-04-2020 4:10 PM
I hope EmilyD is ok but surely someone is able to respond if she is not at her desk for some reason. It just feels like Plusnet do not care if customers have a problem.If they have a staffing issue they just need to tell me that my problem is on hold until things improve, but don't leave me dangling as if I don't exist !!!
Re: Slow internet
17-04-2020 4:21 PM
I just checked again and it is much improved ?
down 41.15 mb/s
up 17.54 mb/s
ping 20ms
Obviously this is acceptable. What has change ?
Re: Slow internet
06-05-2020 4:51 PM
can you look into this again Plusnet it should never be this low no matter what e.g. too many users etc 1.98 mbs download is not acceptable
Re: Slow internet
06-05-2020 5:19 PM
Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at http://faults.plus.net.
Re: Slow internet
18-05-2020 2:36 PM
I appreciate you have a priority system but i am a paying customer and i am getting a very poor service for my money. when will you deal with my problem.i have raised this issue with the Ombudsman CM039389-20.
Re: Slow internet
18-05-2020 4:36 PM
Hi @bazzaman I am sorry but we aren't working anything speed relate and are advising our customers to raise a fault with the link already provided above. I am sorry but we are doing everything we can to support customers the best we can throughout this pandemic, if you can please stick to Ethernet connections rather than wireless to get the best speeds possible.
